TD_9
Posted by sniggy on March 25, 2007 at 05:02:28 from (75.88.176.211):
I have a 1946 model TD-9 tractor, what I'm looking for is the fuel injector line for the #4 cylinder. The tractor is equipped with a bosch pump. These things are not easy to find. my problem is that the tractor doesnot have an ID plate. The other thing that i'm looking for is the shifter fork for first and reverse. mine is badly worn and the trans jams. when you shift into rev. the lever moves over the gear and the trans. stays in neutral .i would sincerely appreciate any help you could offer. thanks
  • Re: TD_9 dej(jed) 10:31:01 03/26/07 (0)
  • Re: TD_9 Janicholson 07:45:30 03/25/07 (0)
