Dim 6V lights
Posted by chadd on March 25, 2007 at 14:24:30 from (4.188.132.56):
Yes, I know that 6V lights are nothing to brag about when in good condition, but as of late they seem to have gotten worse on our W6. I tried running a ground wire to each of the headlight housings, but it didn't seem to help. The backlight has also gotten dimmer. On the high setting, they are only good enough to light up your hand about a foot away with a dull yellow glow, however, they take about 10 or 15 amps of current to operate. I was wondering:
a)If the switch and light box lid needed to be properly grounded
b)If it is normal to get a voltage of 6.45 volts across battery terminals but then to get about 5.44 volts between a ground and the headlight.
c)What gauge wire should be used on 6V headlights (should it be larger than a similar 12V system?
d)The junction block mounted to the box cover was still available, as mine broke off of the box due to age when I removed the cover, and I haven't found a suitable replacement anywhere else.
Thanks.
Today's Featured Article - A Cautionary Tale - by Ian Minshull. In the early 1950s my father bought an Allis Chalmers B and I used it for all the row crop work with the mangolds and potatoes, rolling and the haymaking on our farm. The farm and the Allis were sold and I have spent a lifetime working on farms throughout the country. I promised myself that one day I would own an Allis. That time event ... [Read Article]
