Re: Front wheel seals
Posted by CNKS on March 25, 2007 at 16:41:31 from (204.249.178.32):
In Reply to: Front wheel seals posted by VAJerry on March 25, 2007 at 11:46:54:
Not sure of the Super A, as the different models are not exactly the same. Basically all you need to replace, unless wear is severe, is the dust seal, sometimes called an oil seal (see below), and the bearings, if worn excessively. The cups the bearings run in are replacable in case of excess wear. I have not replaced the bearing cups, but have replaced the cups the oil seals run in. Those seals just keep dirt, etc out of the bearing, and if the tractor sees little use can probably be ignored, but I don't like to leave out parts.
