Re: Farmall 1566 lights
Posted by Allan In NE on March 26, 2007 at 11:40:33 from (148.78.243.25):
In Reply to: Farmall 1566 lights posted by Andre Konstantinov on March 26, 2007 at 11:09:33:
From the factory, that circuit runs from the dash fuse, to the light switch and from there out to ALL the lights including the panel lights.
Nothing is fused via the cab circuit breakers.
Problem is "usually" the light switch and the first place you should look.
However, I've also seen a lot of 'em where the owner will bypass that dash fuse and wire in a circuit breaker right behind the left instrument panel to feed that light switch.
Allan
