Re: Crank Seal
Posted by Tom Windsor on March 26, 2007 at 15:06:31 from (69.40.61.69):
In Reply to: Re: Crank Seal posted by John M on March 26, 2007 at 14:02:21:
yes I am sure. The rear main felt was split. It is inserted into two pieces (don't know proper name) and then pressed together on assembly of the two pieces.
The one for up front is a solid o-ring of felt. I am still looking...maybe I am trying to put it in the wrong place..but it is slides over the crank?????
TW
