Re: Different crank seal question
Posted by Tom Windsor on March 26, 2007 at 17:30:45 from (69.40.61.69):
In Reply to: Re: Different crank seal question posted by El Toro on March 26, 2007 at 16:41:06:
I don't know what a speedy sleeve is, where you get it and how to install it. Can you add some details about this item? This is a common problem and sounds like a wonderful solution.
