Re: Different crank seal question
Posted by gene bender on March 27, 2007 at 03:04:13 from (67.55.226.214):
In Reply to: Re: Different crank seal question posted by Tom Windsor on March 26, 2007 at 17:30:45:
They can be found at any parts store you just need the od of the part you are putting it on. You want to be sure it is long enough to cover the groove worn by the old seal. Thanks TOM for the payment glad the clip worked.
