Re: How big a tire on b. n. puller
Posted by old on March 26, 2007 at 21:09:16 from (4.244.217.209):
In Reply to: How big a tire on b. n. puller posted by Thumper S on March 26, 2007 at 18:26:13:
Beleive it or not but if you can go smaller diameter and the wider your better off. Problem is if you go wide you also got bigger diameter which also means faster speed which you don't want. So you need wider but smaller diameter so you have more torque to the wheels but less speed.
