Re: H generator re-wired!!
Posted by John T on March 27, 2007 at 09:15:50 from (66.244.90.5):
In Reply to: H generator re-wired!! posted by ryanfisher on March 27, 2007 at 08:14:00:
Ryan, Did you wire her up per Bob M"s Wiring Diagrams?????? For an ammeter to work, in addition to it being good, it MUST be wired with its input SUPPLY TERMINAL leading to ONLY one location, that being the hot ungrounded battery post, often via a wire to where the big ungrounded battery cable atatches to the starter switch/solenoid. Then for it to properly register amps into it (charging) or amps out of it (discharging) its other LOAD TERMINAL wires to BOTH the BAT terminal on a Cutout Relay or Voltage Regulator PLUS any BAT input terminal on lights or ignition switch feeds. An ammeter is like a dead short with extreme low resistance continuity between its Supply and Load terminal if its working and MUST be wired as described above so the battery power can get to and feed hot battery voltage to lights or ignition and the gennys output (via the BAT terminal on a Cutout Relay or VR) can get to n charge the battery. The lights cant work nor can the ammeter register correct UNLESS the light switch has a hot battery voltage feed from the ammeters load terminal (or the LOAD terminal on a 4 terminal VR) and the ammeters other Supply terminal gets to the hot ungrounded battery post voltage (usually at the starter switch). If the lights BAT input terminal were wired to the ammeters supply terminal they can still work, but the ammeter wont be registering that current flow. You gotta get hot voltage to the light switches BAT input terminal (from ammeter or BAT on a 4 terminal VR) and the switch to be closed and good to feed that voltage to the lights. Use a simple test lamp to trace down where youre gettign or loosing hot voltage. John T
Home
| Forums
Today's Featured Article -
Restoration Story: 1951 Farmall H - by The Red (John Fritz). I have been a collector of Farmall tractors since 1990 when I first obtained part of the family farm in Eastern Indiana. My current collection includes a 1938 F20, 1945 H, 1946 H, and the recently purchased 1951 H. This article will focus on what I encountered and what I did to bring the 1951 NEAR DEATH Farmall H back to life.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
