Farmall Tractors Discussion Board
Re: Re: Farmall A, Throttle/Governor problem?
Posted by Jim Becker on April 27, 1999 at 20:41:29:
In Reply to: Re: Farmall A, Throttle/Governor problem? posted by Stan(VA). on April 27, 1999 at 19:09:15:
Probably the spring, if not you still need to take it off to see what the problem is.
As I recall, when I pulled a B governor, I had to unbolt the fan shroud to squeeze the governor off without removing the radiator. If there is no antifreeze involved, it might be just as easy to undo the top hose, loosen the radiator and at least tip it forward.
Post a Followup
: Re: Re: Re: Farmall A, Throttle/Governor problem?
