Re: 400 vs. 560
Posted by K.B.-826 on March 27, 2007 at 22:33:26 from (66.188.221.148):
In Reply to: 400 vs. 560 posted by John, OH on March 27, 2007 at 17:51:42:
Most people don't realize right away that the engines in the 400 and 450 actually have more displacement than the 560's gas engine. 400's engine was a 264, 450's was a 281, while 560's was only a 263. 400 with a oversized sleeve kit would also be a 281. 560's engine was rated at a higher speed than the older tractors, and since horsepower is a measure of how much work can be done in a certain amount of time, the tractor with the faster running engine is going to come out looking better. The 400/450's long stroke engine will give it the edge as far as torque goes. So yes, I would believe that a 400 could walk all over a stock 560 gas. Keep in mind that those old 263's can be made to run too. Built to 706 specs, it would give the 400 a run for it's money. Also remember that there's more to it than just the engine. If the 400 has more ballast and better tires, that'll make more of a difference than anything.
