Re: Farmall A running rough
Posted by old on March 28, 2007 at 11:42:32 from (4.244.90.233):
In Reply to: Farmall A running rough posted by kazenza on March 28, 2007 at 10:09:25:
As Jim says and also replace that manifold as it is part of the problem but since its blowing black smoke Jims probably get the answer there and you have a problem with the float or needle
