Re: Shaving an M Farmall Head
Posted by randy hall on March 28, 2007 at 12:32:43 from (209.11.236.29):
In Reply to: Shaving an M Farmall Head posted by Ole Rusty on March 27, 2007 at 21:57:04:
you could use pistons with a one inch dome if you wanted to with a 8060 head. the limiting factor is the thickness of the casting at the bottom. i wouldn't take off over an eighth of an inch.
