Re: Better Picture
Posted by richard in nz on March 30, 2007 at 01:19:18 from (125.239.172.56):
In Reply to: Better Picture posted by IndianaRed on March 29, 2007 at 18:11:13:
No it dont look right, everybody and the shop manual says there should be a double punch mark on the cam gear to line up with the single punch mark on the crank gear, my tractor however only had one single punch mark on the cam gear but this is in the root between 2 teeth to line up with the single punch mark on the tip of the tooth on the crank gear, yours is showing the marks both on the tooth so they never line up properly. I checked mine with the rocker cover off so I could see the number 4 cylinder valves were on the rock when these 2 punch marks were alighned on number 1 cylinder T.D.C. mark. I then timed the mag still with the the timing cover off at number 1 cylinder T.D.C. as there was no marks on the mag drive gear.
