Re: Adjusting clutch rod on 966 with hydraulic
Posted by chadd on March 30, 2007 at 08:52:13 from (155.92.32.35):
In Reply to: Re: Adjusting clutch rod on 966 with hydraulic posted by the tractor vet on March 30, 2007 at 07:50:16:
First off, do you think that it is worth me trying? It has not been adjusted since the new clutch was put in 4 or 5 years ago. Second, if I did it, I was going to do the works (trans brake, dump valve, etc.). Third, I have a few questions on your procedure: Am I supposed to push the rod from the clutch bellcrank to the cylinder in while adjusting the rear rod and how much resistance is enough? Also, if it starts to push the front rod out, is that too much? When I am adjusting the clevis on the trans brake, do I screw it 1/2 to 1 turn onto the rod, or off of the rod (clockwise or counterclockwise) When I am adjusting the bolt for the dump valve, do I add 1 turn in or out (clockwise or counterclockwise)? Am I supposed to put the head of the bolt between the platform and the clutch pedal, or the bolt itself?
Home
| Forums
Today's Featured Article -
Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
