Re: Cub Wiring John T
Posted by Bob Underwood on March 31, 2007 at 00:10:06 from (72.69.101.163):
In Reply to: Re: Cub Wiring posted by John T on March 30, 2007 at 16:00:11:
Thanks again we are almost there. The ARM from gen is attached under the VR. I have a mag so no ign switch . I should remove the jumper from the load side of ammeter and run the L wire to where it was on the switch. Not knowing I ran L term wire to the where it was on the gen resistor, it got a little hot. Do you think I messed up anything other than the wire?
Thanks
Bob
