Re: cub needs an overhaul??
Posted by Denny ('60 Lo-Boy) on March 31, 2007 at 12:33:24 from (76.1.52.84):
In Reply to: cub needs an overhaul?? posted by stevewelker on March 30, 2007 at 18:08:49:
Compression sounds good. Rebuilt will probably get you 120 lbs. 80 lbs. is usually due for a rebuild. Clean the crankcase vent tube as suggested before, adjust the mower just a bit lower in front and most importantly check the adjustment of the valves. Has probably never been done and many will attest that proper adjustment feels like the power doubled. They don't have much HP but have loads of torque when properly adjusted and tuned.
