Re: 400 parts help
Posted by karl f on April 01, 2007 at 12:53:08 from (209.23.168.122):
In Reply to: Re: 400 parts help posted by JayWalt on April 01, 2007 at 09:14:16:
pump is new, "filter"(screen) is new. the reservoir cover gaskets and possibly an o ring at that mount point are the last defect in the system. the return and suction lines both are on that top assembly the gaskets seal, along with the valve bodies. definitely a high pressure leak there, so likely a suction leak too.
karl
