Re: SUPER C HEAD ON 113 C.I. ENGINE ?????
Posted by CSR on April 03, 2007 at 03:33:11 from (192.249.47.8):
In Reply to: SUPER C HEAD ON 113 C.I. ENGINE ????? posted by THUMPER S on April 02, 2007 at 16:52:52:
I just redid a C113 using the TISCO stepped head piston overbore kit. The domes are .375 high. I measured the valve lift prior to disassembly and it was ~.250. The combustion chamber depth to the valves was 1", so I should still have .375 valve to dome clearance. I am painting the motor tonight and will have it fired up in a week or so....
