Re: Loader cylinders bleeding down
Posted by Janicholson on April 03, 2007 at 10:51:06 from (199.17.6.122):
In Reply to: Re: Loader cylinders bleeding down posted by Gary in Mozarks on April 03, 2007 at 10:46:13:
Exactly.
Be careful unhooking under pressure. It may be best to support the load, release the couplings, then put the load on the hoses. Some couplers are difficult to remove loaded, and might leak/squirt. JimN
