Re: 12 volt converson
Posted by john d on April 03, 2007 at 13:33:03 from (69.130.182.233):
In Reply to: 12 volt converson posted by james braley on April 03, 2007 at 13:24:43:
Check Bob Melville's wiring diagrams in the link below. His generous work has saved many of us from eletrical problems.
You'll also need a ballast resistor unless your coil is a true "12 volt" coil. Depending on your alternator choice, you may need an indicator light. If the tractor has lights, you'll need 12 volt bulbs.
Having done a couple of these, I recommend ripping out and throwing away all the wiring except the battery cables.
