Vertical Float Pin for Fast Hitch
Posted by Nifty 350 on April 04, 2007 at 05:46:25 from (192.249.47.9):
I have a 350U with fast-hitch. The instructions say to extend the cylinder all the way up to install the vertical float lock-out pin (I just purchased it from an IH dealer) located at the bottom. It goes in about half way then stops because there is misalignment between the pin holes of the cylinder bell crank and the side plate.
I’d prefer not to go to a smaller pin. Any suggestions?
