Re: 1066 Hyd. Assist Clutch - Hey Tractor Vet
Posted by Owen Aaland on April 04, 2007 at 07:16:29 from (65.165.246.155):
In Reply to: 1066 Hyd. Assist Clutch - Hey Tractor Vet posted by Michael Sheik on April 04, 2007 at 05:06:08:
If the pins are installed correctly there should bde a 1/4-20 threaded hole in the center of the clevis pin. You can screw a bolt in there to use to pull them out. Try soaking them with penetrating oil for as long as you can. Behind the pressure sender is the lube pressue relief valve. It is held in with a 1/8" pin through the MVC. No way to get it out without removing the outside plate. Also check the TA pressure dump valve located just above the pressure sender. It is quite possible that the leak is there and running down on the sender.
Home
| Forums
Today's Featured Article -
Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
