Re: M wont start after rain
Posted by old on April 04, 2007 at 10:15:56 from (4.244.219.63):
In Reply to: Re: M wont start after rain posted by eshoreboy on April 04, 2007 at 09:53:00:
Most tractors have that points cover on them. Yes they can be a pain to get to pop loose. What I do is tap them with the handle of a screw driver to get them loose. Don't tap to hard and when you tap sort of tap up words so it will come up when tapping on it
