Re: M wont start after rain
Posted by glennster on April 04, 2007 at 13:51:03 from (68.77.49.48):
In Reply to: Re: M wont start after rain posted by eshoreboy on April 04, 2007 at 09:53:00:
if you have a vertical distributor, it is probably a delco, they were used to change from a magneto to breaker point ignition. the tune up kit is different than the regular ih kit.
