Farmall Tractors Discussion Board
Re: Super C update
Posted by The Red on April 29, 1999 at 07:09:52:
In Reply to: Super C update posted by Milan D. Radakovic on April 28, 1999 at 08:56:06:
Definitely top dead center Milan. When my article gets posted you will see I had a tremendous amount of trouble on the valve clearances. I would not be concerned about turning it.
When I FINALLY got the clearances correct this is what I did. I watched the exhaust then intake open and close. Then I used the hand crank and turned until the mark was on TDC for #1 and #4. Same procedure on #2 #3 but with the mark 180 degrees. I.E. straight down. I made several passes to be sure.
Post a Followup
: Re: Re: Super C update
