Re: 5288 speed transmission
Posted by Joe Schmitt on April 06, 2007 at 14:17:50 from (216.222.172.77):
In Reply to: Re: 5288 speed transmission posted by Pete1468 on April 06, 2007 at 10:59:36:
Thanks for the reply, The gears are locked on the shaft with snaprings and thrust washers ,these are all tight with a few thousand of clearance for rotation. The syncro blocker carrier was replaced and also is tight.The syncro carrier drums that couple the gear to the blocker also was replaced.It all feels good when I snap it into gear both in the tractor( through the shift cover ) and on the bench, but with power applied it pops out.I also studied the shift fork thinking it may be bent, but it`s pretty heavy cast and does`nt appear to be.
