Re: farmall cub will not crank
Posted by old on April 06, 2007 at 15:19:51 from (4.244.222.158):
In Reply to: farmall cub will not crank posted by charles whatley on April 06, 2007 at 14:52:51:
Pull the air intake tube off and make sure you have a good sucktion at the carb. Hold your hand over the carb and crank the engine over, it should try to suck your hand in, if it doesn't then you have a vacuum problem.
