Re: 5288 speed transmission
Posted by hydro on April 07, 2007 at 07:41:10 from (74.34.74.84):
In Reply to: 5288 speed transmission posted by Joe Schmitt on April 06, 2007 at 10:09:42:
I have a 5288 I bought new in 1982. I am not an expert on transmissions but have had this problem a couple of times. Shifting between 3rd and 4th is done with the aid of solinoids. When I had trouble it was a solinoid problem.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
