Farmall Tractors Discussion Board
Mag Help
Posted by Brian '35F12 on April 30, 1999 at 16:07:14:
I just mounted my mag back onto my F12 and followed the service manual for setting it up and installing. I then put a plug on the no.1 plug wire and tried crank'n her (none of the plugs are installed) I set the no.1 plug against the block but I couldn't get a spark. I remember when I cleaned the mag I was turning it by hand a zapped myself but nothing too stunning if you know what I mean. Should I send it out for a re-work, or how else can I check for good spark out of her. I've been working on this tractor for almost a year and am soo close to getting her ready to start up again that I hate leaving the garage even more than normal. Thanks in advance.
Post a Followup
: Re: Mag Help
