Re: M front crank seal relacement.
Posted by Owen Aaland on April 10, 2007 at 20:05:07 from (65.161.86.75):
In Reply to: Re: M front crank seal relacement. posted by wagsw900 on April 10, 2007 at 16:56:46:
Before tearing into replacing the front seal, make sure the crankcase ventilation system is working properly. Originally the front seal was installed with the lip facing forward to keep dirt from being drawn into the engine. Unless things are really worn out, the front seal will not leak if the venting is working .
