Re: Getting bolster bushings out
Posted by MN Scott on April 10, 2007 at 20:14:40 from (206.9.216.30):
In Reply to: Getting bolster bushings out posted by Randy as in Randy-IA on April 10, 2007 at 18:50:32:
I've found the gas wrench works the best to remove bushings. For it to work they have to be steel backed. Just heat the edge and hit the O and you'll burn thru in a second. You will not hurt the casting as it will not have time to get hot.
