Re: clutch?
Posted by kfox on April 12, 2007 at 11:08:53 from (63.18.189.210):
In Reply to: Re: clutch? posted by CENTAUR on April 12, 2007 at 09:21:51:
I replaced the clutch in a H last year and had the same problem. I finally found the splined center of the new disk was a little longer than the old disk and the splines on the shaft had a small shoulder where the old disk had run. A little polishing On the shaft splines with the Dremil tool and everything was fine. ken
