Re: clutch?
Posted by Red Dave on April 12, 2007 at 11:30:31 from (66.216.141.163):
In Reply to: clutch? posted by boochie on April 12, 2007 at 08:44:32:
Did you adjust the fingers on the pressure plate to specification before you installed it?
This where you lay it face down on a flat surface and measure the height of each fimger. The procedure is detailed in the Blue Ribbon Service Manual.
If they are not in spec and even, clutch adjustment will be way off, or maybe impossible.
