Re: Farmall A HAND CRANK KICK BACK
Posted by Andy Martin on April 13, 2007 at 13:03:14 from (216.150.108.41):
In Reply to: Re: Farmall A HAND CRANK KICK BACK posted by CSR on April 13, 2007 at 08:31:48:
Rotate the mag away from the engine. Then slowly crank to TDC. Rotate the mag toward the engine until it trips. Then you are set at TDC.
Unless the impulse is sticking it will not kick. As other have said, only pull up on the crank with your fingers only and a kick will not hurt you bad.
If the tractor does not run well bu truns better with the mag set earlier the mag needs to be repaired.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
