Removing M belly pump
Posted by TMQ on April 13, 2007 at 18:20:49 from (67.1.184.223):
I'm trying to remove the belly pump on my 48 M to fix a leaking seal. I removed 4 bolts and all the plumbing, everything is loose but will not drop out. Any advice? Does the coupling hold it in? Is the shaft seal an easy fix? Thanks in advance.
