Re: Removing M belly pump
Posted by glennster on April 13, 2007 at 19:19:29 from (68.60.242.156):
In Reply to: Removing M belly pump posted by TMQ on April 13, 2007 at 18:20:49:
pt a couple of the lower bolts back in a ways, then with everything in neutral and the wheels blocked, you and rotate the coupling till the keyway points up and down. best to have a helper at this point. get a floor jack under the pump, remove the last two bolts, have a guy on each side of teh tractor and lower it down. its heavy and hard to hold on too.
