Re: Farmall A HAND CRANK KICK BACK
Posted by Roger Mills on April 14, 2007 at 08:12:11 from (71.37.117.162):
In Reply to: Farmall A HAND CRANK KICK BACK posted by Mark J on April 13, 2007 at 06:40:40:
Srivice manual says the impulse trips at TDC and normal timing when running is static at 35 degrees before TDC. A comment: if the impulse coupler does not engage it will make a weak spark when hand cranking but usually not enough to "fire". It can try and that will cause it to kick back--or cause the starter to crank slower than normal with a hesitation when it tries to fire.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
