Farmall 300 no start
Posted by Hogman on April 14, 2007 at 14:20:38 from (67.141.208.56):
Hey guys the 300 won't suck up the gas to the pistons......Took the carb off put the standard rebuild kit in and it still floods the carb and the plugs are dry.......Took carb off again and held a rag with ether on it uder the intake turned the key and it started......Did it with gas the same way and it started.......Now what is the freaking problem?????Thanks for any answers........Scott
