Re: Farmall 300 no start
Posted by City-Boy McCoy on April 14, 2007 at 16:26:40 from (68.221.177.158):
In Reply to: Farmall 300 no start posted by Hogman on April 14, 2007 at 14:20:38:
I totally agree with what old said. It is either an intake leak, or a lack of valves sealing, or rings sealing enough against the cylinder walls to create enough suction. I had a Super A that was half worn out and if it sat for a month I had to squirt a little gas (or oil, which temporarily boosted compression) into the plug holes to get it to suck enough to draw the fuel/air mix up from the carb. Otherwise, I would choke it and gas would drip from the carb but not get up to the cylinders. Once I got it started that way, it would start fine from then on, as long as I ran it once a week or more often. mike
