Re: 300U TA question
Posted by D Slater on April 14, 2007 at 19:02:30 from (64.12.117.8):
In Reply to: Re: 300U TA question posted by gleggans on April 14, 2007 at 18:47:52:
Probably, but need more info. With tractor rolling in gear does it slow down or stop if you pull T/A lever back while putting pressure on brakes? Is tractor hard to get shift lever pulled out of gear sometimes? Sometimes someone adjusts linkage from T/A handle so much that the pressure plate levers are pushed far enough to hit. Does it grind as soon as lever starts back or when near all the way back.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
