Re: Super M
Posted by Jason Simmerman on April 14, 2007 at 21:56:24 from (71.168.38.251):
In Reply to: Super M posted by Jeff McBride on April 14, 2007 at 20:10:40:
Well, if it were the governor it would just lose power not pop and miss so I wouldn't suspect that "at least right off the bat"... Might be a cracked or not so well sealed gasket on the manifold, but not likely. With that miss and it missing slightly at idle and if it idles down nice I suspect you have one of two things are going on here. You have a sealing problem with one of your cylinders, or you have a cracked head. Under load a small miss will get worse because cylinder pressures go up IE getting hard into the governor and governor is adding more fuel and air. I'd get a compression gauge if you don't already have one and run the motor for about 10-15 minutes and run it around alittle and shut her down. Ensuring you have a good strong battery and hooking a charger to it pull all 4 sparkies out of it and screw your compression gauge into the sparkie holes. Crank her over 3 or 4 times and see what you got. My dad's M with a Super M sleeve and a domed piston kit which was redone 30 years ago has almost the same problem. I found that he has a valve leaking on the number 2 cylinder. Motor makes darn good compression particularly considering it's age between rebuilds (about 120 psi on cylinders 1,3, and 4 but cylinder 2 is only about 100). You should only have 10% of deviation from highest to lowest in your compression numbers. If you find you have one cylinder that is much lower than another squirt some motor oil in the cylinder and retest. If the pressure goes up by a noteable margin you have a ring sealing issue, if it stays the same it's most likely a cylinder head issue. Now, being it's a new rebuild maybe the rings aren't fully seated yet but in any event. Could be a weak valve spring also. I'm assuming you replaced all the components in the heads, but sometimes there are machining errors that occur. I'd do a compression check and go from there. It seems like you've covered everything else. Now make sure the motor is indeed sound.
Home
| Forums
Today's Featured Article -
Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
