Re: Super M
Posted by RustyFarmall on April 15, 2007 at 06:56:12 from (66.43.253.62):
In Reply to: Super M posted by Jeff McBride on April 14, 2007 at 20:10:40:
Did you thoroughly clean the carb before you "put the kit in". Did you adjust the idle and load screws according to specifications? Your M exhibits classic symptoms of fuel starvation. A lot more is invoved in a carb rebuild than just "putting in a kit".
