P.P. S.
Posted by A. Bohemain on April 15, 2007 at 09:43:56 from (207.170.88.120):
In Reply to: P. S. posted by A.Bohemain on April 15, 2007 at 09:40:45:
I notice you adjusted the valves. Did you grind/replace them and the seats?
Nice new rings often cause marginal valves to fail, and vice versa!
At least you've got a bunch of new stuff to check! Don't give up, you'll find it!
