Farmall Tractors Discussion Board
Re: Re: Overhauling a Farmall H - How hard is it?
Posted by The Red. Bummer :( on May 02, 1999 at 04:35:13:
In Reply to: Re: Overhauling a Farmall H - How hard is it? posted by RKS on May 01, 1999 at 17:51:41:
I have the engine seals. Its simply that I didn't have a need to split the tractor and I did the overhaul in the frame. I had no reason to pull out the crank nor the cam. So I am not surprised it leaks a tad. I have more leaks around the dang oil pan and the front timing cover than the rear seal.
Post a Followup
: Re: Re: Re: Overhauling a Farmall H - How hard is it?
