Re: IH 300 utility ...PTO Questions/Interchangeabi
Posted by Wardner on April 15, 2007 at 14:37:04 from (4.154.244.234):
In Reply to: Re: IH 300 utility ...PTO Questions/Interchangeabi posted by Wardner on April 15, 2007 at 10:56:38:
Ben,
I forgot to mention this earlier but the handles are different on the utilities. It's primarily due to the seating position of the operator. In addition, the valve bank on the utes may be in the way. The handles on the row crops are verical whereas the handles on the utes are nearly horizontal.
Could you modify one? Perhaps. I wouldn't. It is more than just a piece of flatbar. There is a latch, spring loaded thumb button, and linkage that complicates things.
I should also mention that the IPTO drive train starts with the engine clutch spring cover that bolts to the flywheel. From there the tractor needs a sleeve and gear, a driven gear, two more shafts, a coupling, and a bunch of bearings. This is all needed before the IPTO gets power. You may have this stuff but you need to check the serial number suffix.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
