Re: IH 300 utility ...PTO Questions/Interchangeabi
Posted by Wardner on April 15, 2007 at 10:56:38 from (4.154.247.158):
In Reply to: IH 300 utility ...PTO Questions/Interchangeability posted by Ben in OH on April 15, 2007 at 09:14:24:
You need to check the serial number before you start dreaming about a PTO or IPTO.
The letter suffix will need to be "R" if you have a Torque Amplifier (TA) and want to install a PTO.
The letter suffix will need to be "S" if you have a Torque Amplifier (TA) and want to install a IPTO.
The letter suffix will need to be "P" if you do NOT have a Torque Amplifier (TA) and want to install a IPTO.
The reason for this is that there is hardware ahead of the IPTO that needs to be in place. I don't own a utility but I think alot of that stuff was optionally deleted on those models. A parts book will help you understand the the different setups.
