Re: The B is finally unstuck!
Posted by El Toro on April 15, 2007 at 17:40:36 from (152.163.100.197):
In Reply to: The B is finally unstuck! posted by bshannon on April 15, 2007 at 16:33:43:
Now would be the time to install a new sleeve and piston kit. New seals on the sleeves will prevent coolant leakage into the crankcase. Hal
