The B is finally unstuck!
Posted by bshannon on April 15, 2007 at 16:33:43 from (72.2.216.253):
After 9 months of soaking, I finally got the neighbor over to see what else we would have to do. After taking off rod caps on the stuck cylinder we were happy to see the other 3 pistons move. A block of wood and a couple of hard well placed blows got the other one loose! We took all the pistons out and going to put new rings in. We might get the little bugger to run yet.
