Re: Brakes on a regular
Posted by Tom Windsor on April 15, 2007 at 17:50:32 from (69.40.38.48):
In Reply to: Brakes on a regular posted by Dan in Ore on April 15, 2007 at 16:56:31:
The regular brake system is sorta convoluted. It has a "hand operated" lever on the left side to apply the brake on the left wheel only. Then, there are cables that are hooked to the left and right side on the rear. The cables hook to a lever on the front wheel assembly. So, if you turn right, the right cable applies the brake on the right side and vica versa.
TW
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
